frozenhawaiian
why fix it right when you can fix it right now?
cxman said:that seal is not glued in its melted if you buy a all balls bearing kit a new seal comes in the kit
the speedo drive washer is FuBARED so check that it did not wreck the speedo drive plastic drive tangs if it did the speedo
wont work and last check that the speedo cable and speedometer turn and that a seized cable or head did not cause that
you need part number 8 very common and cheap from any honda dealer
http://www.hondapartshouse.com/oemparts/a/hon/506f7f1cf8700229747b88e7/front-wheel-disc
I'll check that next time Im at the shop, hopefully the speedo unit is fine. the bearings are crap so they do need to be replaced and I have a set of drift punches so I can get the old ones out without too much trouble
