Parting out a CB900F in T.O.
C
cafeole
Guest
There is no : seat, side covers, headlight,
Tank is there but a bit rough,
May have a yosh exhaust
Let me know what you neeed and I will check.
would you happen to have the dual disk set up? Rotors, master and all the hoses?
What year is the 900?
Cheers
N
It is an 81.
I have eyes on the rear swing arm and rear brake setup.
Everything else is up for grabs methinks.
I'll try to get some pics tonite.
Steve
Here ya go.......there is also a nice rear light assembly not in the pics.
Thanks for the pics!!..
how much for the front dual disk set up?
both rotors, all 6 screws to the rim that hold the rotors in place, hoses, & master cylinder?
Also, how much for the rear shocks?
Is this your bike?
Cheers
N
would ask about forks since 900 had slightly shorter forks than the 650, but those dont look that healthy :D
I'll check those items out....where are the numbers on the carbs?
Steve
May be able to use the pipe if it is not too rough
if they where vb43c i would have grabed them would just need run 110 instead of 120 jets, incase wondering dif vb43 is 43mm and vb44's are 44mm the letter is type honda had four type carbs at tim a,b,c,t c being the best a being next best b being okay and t being twin fuel intakes.
I don't know anything about the motor. It was obviously running at the time of the accident. My friend had it running after that and then put it in storage till recently. $150 or I will take it down for scrap aluminum. I'm in the process of taking the bike apart now.
Steve
Hey Steve,
Any word on the dual disk set up? Rotors, master and all the hoses?
Looks like front discs are 5 bolt setup. $50 if anyone wants them. discs, hoses, master, calipers.
this a good set up noel, its same brakes that are on the 81 650c
