sebatron
Coast to Coast
Hey all,
Seeing the jump in the little honda's of late and given our numbers are getting stronger, I wanted to create a one-stop thread for modernising the charging system.
Problem is, I've got some gaping knowledge gaps with the whole thing, but that phase of my build is fast approaching.
My CB125, for example, uses a sealed beam 6v headlight, 6v bulbs, and a 6v coil. It charges from 500rpm according to literature, and uses the old selenium rectifier but no regulator.
From my understanding, converting to 12v in this case just needs all bulbs, coils, and battery changed to a 12v item. The use of a 12v regulator/rectifier such as the radioshack job in the $50 thread seems perfect too.
Have I got anything wrong so far?
Below is the schematic for an SL125 - most small CC 6v hondas will be the same.
First question I have is, how many Ah should a 12v battery have to run in this system?
