Re: My First 1974 cb450: Cafe Project!
Haven't updated my thread for a week! Well I made some progress! I'd like to thank Flugtechnik for all his support as I was PMing him for advice.
The first day I was finally about to work on the bike was a few days after I got it. I had free time after class and decided to remove some parts. I took out the seat, which was mounted on ghetto-like from the previous owner, however it works
. Then I removed the air filters, battery box, and rear view mirrors.
This guy was hard to remove.
I needed more leverage so I found something to use as a breaker bar. It was a long pole, but it made the removal so much easier.
Just a few stuff removed put on the floor. (First Day Progress lol)
And this is how it sat after the first day of working on it. I tried charging the old battery using my car battery, but no luck.
So for the past few of days, I got my multimeter from the mail that I ordered on ebay. Works pretty good. Next thing I did was check all the wires to make sure they were working and had a closed circuit. The first thing I bought for the bike was a new battery.
The past few days have been pretty much trial and error. Even with the new battery the bike wasn't getting any power. I found that the fuse was broken so I bought a replacement from my auto store. I replaced the fuse and with my fingers crossed I turned the key. But still nothing. I thought there was an issue with the ignition switch but I checked the continuity last night. Turns out that the ignition switch functions properly.
Well this afternoon while trying to open up the starter, I noticed there was something wrong with the wiring of my bike looking at the Clymer and Glenn schematic. The two prongs of the starter solenoid looked like this:
I finally caught on that the bike wasn't getting any power because the red wire/terminal was not on the same prong as one of the other red wires/terminal that attaches to the battery. It was an "A-HA!" moment. I hastily switched the connections to this:
And voila! I turned the key and the lights went on. I'VE GOT THE POWA! I literally screamed "Yes!" in my garage and honked the horn more than necessary.
Electrically, the bike works well. Lights, horn, and even the starter works! I'm glad that the bike turns over. This bike was too good of a deal. If the previous owner had known the fault, the bike would have been a little more! What a difference! The only thing that I need to figure out is that the neutral indicator light does not go on, nor do the high beams work. I opened up the right handle bar controls and I think it has to do with something missing or not functioning properly in there. Also the taillight does not flash/illuminate any brighter when I squeeze or press on the brake. I noticed that the electric starter works even when the Kill Switch is set to off. Is that supposed to happen, just that there won't be any spark?
