Dammit! Just snapped off a bolt in my CB400f rocker cover.
donmac55
Any suggestions on how to get it out? I used a torque wrench on the same settings as the cylinder head, then heard the snap. What's the best way to get it out? It snapped just above the threads.
Depending on your access, you can dremel a screw driver slot, tig weld a little stem with handle, drop a hex nut over the stem of the bolt and spot weld the nut to it, using a guide bushing drill a small hole then tap a torx screw driver in the hole. Most likely it's still loose and hasn't bottomed out in the hole, even a sharp punch can coax it out, or needle nose pliers.
dont panic it will come out super easy unless it was siezed threads or bottomed uot
just get an ice pic and work it out
