My front brake was locked up after adding fluid and pumping them. No play in the lever. Bled them and took apart the master cylinder and cleaned it. Rode for about 10 miles and they froze up again. Was able to open the bleeder to relieve the pressure and rode home. Pumped them a few times after I got home and now they are locked up again. The master cylinder has a good sized hole (not a tiny hole in the piston) for letting the fluid back into the master cylinder so I don't think it could be blocked. Air in the lines would make the lever squishy not hard, right? Didn't think it could be the calipers because opening the bleeder valve released the pressure (temporarily) Any thoughts?
