Care to share a little inspiration?
I'm loving little bikes more and more lately and this one is awesome.
xb33bsa said:
well, that one you can see the fails right away, if you know what you are looking at
the only 2 rear vertical frame tubes are not beefed up unless they replaced them and made them look original ::)
the loads are extremely different on a single shock frame
basically the shock and swinger pivot are trying to tear the frame apart,right there at the weak point, above the rear motor mounts
totally diffferent than what the frame is designed for
the top shock mount is really adding to the grief as it is hung out rearward compounding the stupid with twisting loads on those 2 tubes
and the entire rear frame is removed
it actually contributed to absorbing laterall loads at the swinger pivot, now with the much longer swinger the loads are even higher with a reduced capacity to deal with them, than even the original had
I'm not wishing to drag the issue on, but I built and ride such an animal and I'd question your analysis of the situation. However, if you are an expert, I'll need your help before I find myself skidding down the road on my butt. ::)
i haven't seen your machine, is it also poorly thought out with structurally dangerous, ignorantly conceived design details ?
Nope Drewski's machine is track tested and he rides the crap out of it, although it is a Kawi triple AKA widowmaker/flexi flyer so any upgrades to the frame make it Better. ;D it's bike 2 in his sig line and is a wicked machine.
Doesn't look all that efficient. The fulcrum angle isn't really direct and puts a lot of stress on a small bearing load area. Also it looks like a converted hydraulic piston swash plate pump.
Honestly I though it was swash plate pump at first
It's efficient in several ways, particularly in their absence of valves, high compression with the same power stroke as a 6 cylinder, and it's low vibration...
http://thekneeslider.com/duke-engines-5-cylinder-4-stroke-3-injector-valveless-axial-engine/
http://www.dukeengines.com/technology/overview/
yup and i think the entire design started with the idear of the way the cylinders have no poppet valves but slide past ports
it would be interesting to see the cylinder top/port area in more detail
