Cleaning up my handlebars, what to do with Reservoir?
Redcon
Hi!
So I'm thinking of "cleaning up" my bars. I just can't figure out how to get rid of the brake Reservoir off the bars...anyone have any good resources to read up on doing something like this?
Thanks!
'Linked' brakes.
Fit a larger rear master cyl, proportioning valve and have foot only (been there, done that, sometime in the 80's ;D )
I'm not clear on this. Do you have a late model master cylinder with separate reservoir that you don't like the look of or an integrated unit?
What I did on my last project was to fit an aftermarket M/C with integrate reservoir. It's as clean as you'll get and still have functional brakes.
Could also get a BMW/Moto-Guzzi cable operated Brembo and have front brake master cyl under tank
(I've done that as well 8) ;D )
Or you can use small section of tygon hose to replace the mc reservoir but it leaves you with little safety margin due to decrease in fluid volume. Usually seen on rear brake mc but can also be done on front I suppose.
