Cb360 clutch pushrod bent, slight oil leak
Sderbyshire
Into Sailing, classic Triumph cars and motorbikes.
My cb360 is running great, but there's a slight oil leak from the clutch pushrod seal.
I replaced this when the engine was out, so am surprised/disappointed.
On inspecting i see that the pushrod is bent!
Theres clear daylight when its rolled on a flat surface, guess this is the problem as the seal cant cope with the oscilation?
So a new pushrod and another seal are the order of the day?
Steve
If you're careful, you should be able to lightly tap it straight with a brass hammer.
Thanks deviant.
I did think about flattening it in a vice/hitting it with a hammer.......but instead ordered a second hand one from a breaker in the US.
So am awaiting its arrival.
Luckily i have a couple of other bikes, classic car, yacht to play with in the meantime
Steve
