Finnigan
Over 1,000 Posts
Some background: When I brought my cb450 project to life with stock carbs I didn't know correct tuning and what to look for so when it ran like crap I went the route of new carbs. These larger racing carbs gave me hell so when I went back to stock it was easy to troubleshoot and get it running well.
With the dual channel wideband air/fuel sensors on order I drove the bike daily and racked up about 300 miles with the spark plugs looking darker than I'd like but the bike seemed to be running well; no back firing, idle well, snappy throttle but maxed out at around 75-80mph.
Install: I got the exhaust bungs welded in and made sure there were no exhaust leaks when I put the pipes back on, I used heavy duty clamps on all the slip fittings and exhaust putty around the seams for good measure. Wiring was a breeze but had about 8 extra feet of thick cables that I had to tie wrap under my seat. I calibrated the sensors in 'free air' and started the bike to find that my idle was rich at ~9-10 A/F.
Tuning: For reference Stoich A/F is 14.7 and most naturally aspirated engines are happy at idle in the 12-13 range, ~13.5 for steady 1/2 turn throttle and ~14 for WOT (thats what my researech showed me, if anyone has different numbers I'd like to hear about it) The meter responded to pilot screw adjustments and the bike seemed to idle fine in the high 12s. At any RPM the bike dove back into the 8-9 range..WAY too rich.
I swapped my main jet from 150 to 140 with no difference, then I found some thicker needles from another set of carbs and put those in. Partial throttle is now 10-11 range but I'm getting backfiring on deceleration (confusing since this is a lean condition). The plugs have a clean porcelain look with dark black around the thread rim.
Conclusion: I wanted to get a good baseline with stock carbs before putting the racing carbs back on and tuning with the AF sensors. I'm getting mixed signals from what i've read about the engine (popping on decel) and what the meter is telling me.
Anyone have thoughts or experience?
