No, it was working just fine and the bike was running when it just died. I couldn't get it to restart and started trouble shooting, that's when I found that it wasn't getting 12V.
No, worries Murray. I got a good deal on a set of them. I'm pretty sure the accessory terminal didn't come about until the 1100, the Dyna instructions specify splicing into the green/white wire running to the flasher relay.
Lesson learned. Don't trust 30 year old fuses. They will look intact until you pull them out of the fuse block and they fall apart in your hand. Once I figured it out and replaced the fuse it fired right up. First time I've gotten to ride it since replacing the ignition and it runs better. I think the ignition may have been intermittent issues leading up to its death.
I put this thread in Restorations because it didn't fit anywhere else but it was never intended to be a real restoration. I was just supposed to be a get it reliable and presentable and back on the road kind of deal. I think I'm basically at that point now. I'm sure small fixes and improvements will continue though.
Was it the original one with replaceable filemint? First thing I replace on all old Hondas s that main fuse then the glass tubes for near auto blade fuses.
Replaceable filament? I dunno, I've never seen one of those. It was the glass tube type one for the turn signal and brake light circuit. I pulled it out of the holder to get a better look at it and as I turned it over one of the metal end caps came off in my hand. Replaced it and the magic started working again.
Check your main fuse by the battery if it is still a black plastic housing with 2 nuts holding a strip of metal change it as the crack and cause all kinds of gremlins
It's been quite a while since I updated this. I've made a few upgrades. Got this awesome Vetter from Murray (cxman), it makes the early morning ride to work much nicer.
Here is where I'm at now. Things are sorted out pretty good and I've been riding as much as possible. This thing eats highway miles for breakfast, lunch and dinner with highway mile snacks in between. I need to get a new set of rocker cover gaskets as the ones I have leak all over my boots. It needs a few other tweaks but it gets me down the road and that's good enough for now.
I think Murray may be right about the cam seal. I took a look today and it looks like there is oil coming from the left timing belt cover. I haven't pulled it off for further investigation but I'd bet that cam seal isn't healthy and that's why my left boot is so well lubricated.
Today on the way home she started running like crap all of a sudden. It would idle but when I tried to accelerate it wouldn't go. When I opened it up to near full throttle and the second barrel opened up it would accelerate all of a sudden. I limped on home as best I could, let it cool down and opened up the carb for investigation. I found a little piece of trash in the primary barrels main jet. As soon as I got that cleaned out it went back to running normally. Don't know how if made it past my fuel filter but I got it resolved.
So, I've come to realize that my suspension is clapped out. I knew it was soft when I was solo but I took my wife for a long ride the other day and noticed how much easier it was to scrape in turns. With the extra weight it bottoms out rather easily and doesn't take much leaning to scrape the exhaust. If I get some money in the near future I'll look into replacing that.
