FRANKENHONDA II the 1982 DOHC CB 750F2 Build
I was looking for some inspiration for the damper mount came across this mean setup, no chance of a tank slapper on this ride
Always the way after you make the purchase you come across something cheaper
Seriously Indonesia is heaven for cafe race builders everything’s is so cheap
So only had a two week break, and the newest addition to the clan has managed to keep me pretty busy so progress has been slow at best
Because I couldn’t find the stickers anywhere I’ve decided to get my brother to make them up. But first he needed a template.
So out came the butchers paper, after a few lines it became apparent to me that I will never become a brain surgeon.
After scrawling like a reforming alcoholic for a bit I managed to come up with something that vaguely resembled the decal
I’m not expecting much more progress this break as I fly out on the first :/ unfortunately I haven’t got anyone to sponsor my motorcycle addiction so I’ll have to keep on working.
So I thought I’d try my hand at making a tray for the battery and electrical harness out of ..... fibreglass.
I should have known how this would end up but I’m a glutton for punishment , but this is all about sharing.
So it all starts pretty well, I kept telling myself preparation is everything
Checked all the components would fit, seemed a little tight (a little too tight in hind sight)
Then I used some wax as a releasing agent and began the fibreglassing
I put some steel straps in for additional support
Came out pretty rough as I was trying to lay down the fibreglass in a tight spot and was having difficulty getting it to conform to the shape of the mould
Then the battery was too tight booo
It’s too rough for my liking so I think I will look at fabricating it out of steel using this for measurement and as a guide
Oh well fly out tomorrow so I’ll have 6 weeks to conjure up a new method
Looks like a good guide for the steel attempt. Live and learn my friend.
This is an awesome thread! Excited to see what numbers you end up with, with regards to height under engine, rake and trail. I have the same fork as you, but I'm building a Suzuki GS750.
Cheers, the hand brake has been on for a bit with the introduction of Jnr, and Work.
Maybe when I go home I’ll measure the rake and trail, I’m another week from flying home.
Luckily My old man has been chipping away at a switch assembly
This was the base shape
Then he housed the micro switches
Tapped the thread for the two clamping bolts
Then had to come up with a plan on how we would run the wires
Ended up running a channel on the underside which will exit through a single hole on the inside of the housing
Just trying to find some cheap flexible steel cable to run the wiring through
Dad found a 15m for but it’s like $167 bit exy
Still have to finish shaping them then finally anodise the housing black
But it’s looking pretty cool,
Bit more shaping has been done to the switch housing, nearly there I’ll be home tomorrow so I’ll have to remove the top triple again so we can skim the top of it flat
They’re coming along just need to find someone in Melbourne that can etch in the logo
So finally got into the shed with old man Murphy, we had to finish the internal channels on the underside of the housing so the wiring will be discretely run on the underside of the handle bars. Hopefully without getting squashed.
So into the mill and a little at a time we deepened the channels until the wiring would fit
So next was the test rub for the left hand switch block
Using the dummy handle bar the left hand switch block seemed to work
Once these have been etched and anodised we may even use resin to hold the wires in place still undecided
Both switch blocks on the dummy bar
Next I wanted to take the scratched out of the top of the triple
We set it up then skimmed the top
Came up good need to get it hydroblasted then engraved, anodised then I’m going to fill the engraving with gold powder coating same as the rims should look the goods hopefully.
Now I need to clean the shed before I can start working again then I’ll polish up the switch blocks
May even mock it up on the bike too, just to see how it looks
Looks like she’ll take lefts better than rights
