Hey everyone,
Just posted on HT last night as well, but figured more heads are better. I've been doing some research and testing and have been having some hard luck, so I'm hoping for some great suggestions from you guys to help me out
Quick backstory: Bought bike, hadn't run in 25+ years, changed the coils and condensers and some other mild things, started right up. 2 years later (don't ask why) I decided to start tinkering and have done some mainly cosmetic upgrades, again nothing major at all. I got her running again last week, may have been on one cylinder, not sure as it was running quite rough. Did the timing, and have triple checked it and it is DEAD on. We're getting spark, and the plugs are wet, so I'm confident I'm getting fuel. But it is not turning over even now, and it's getting quite frustrating haha. Last week, after doing the timing we couldn't get it to start and run again for more than a second or two after clearing the bowls a bit. Now, it won't even do that. So it won't even turn over. It seems like the most major thing I did was the timing that was different, but I've verified several times over that it's correct. Today, I pulled the carbs (they were rebuilt 2 years ago) and I put in some new main jets (115 thanks to pods and exhaust) as well as corrected the float bowl height, actually increased it to about 21mm.
At the very end of the night, my friend and I found that one of the spark plugs was a dud and is not firing at all, which is weird. But it did still run 2 weeks ago, AND I know these things can start and idle on one cylinder. So I will grab new plugs, but I am looking for and open to suggestions as to what other pitfalls I should be looking for.
Really appreciate any advice and am looking forward to hearing all your thoughts. Thanks very much!
TL;DR - Wiring correct, timing right, plugs are wet, fuel in bowls, good spark, no start.
Dan
Dan
