I was able to get everything installed last night. I had to grind down the DCC shift linkage arm a bit for the Universal linkage shaft to fit on. All is well there, but still need to get the correct spacing between the rearset arm and shifter arm for it to shift smoothly. Having a hard time getting it to Neutral.
As for the brake side, I took the rear wheel off, rotated the Brake Cam 180deg which allowed the brake arm to be pointed up to about 12 oclock instead of 6. This will allow the brake to operate in a pulling fashion instead of pushing. The only issue i have so far is that I cannot pull the brake enough for it to actually get the brake pads to engage to brake. I have the arm at its shortest length, but it still wont brake for me. I will revisit later tonight to see if i can adjust the angle of the rear set arm to preload the brake a bit more.
some things i need to complete is getting a longer return spring for the brake pedal and find a way to attach the rear brake light spring. I dont think it will reach in the stock mounting bracket.
I will try to get some pix too.
