raptormeat
Left and right, respectively.
Looking at them now, i can see some brown, before they just looked grey. I believe they are a bit too rich still, yes?
Couple things...
The oil on the R/H threads I believe is due to the fact I helicoiled my plug threads on that cylinder, and had to use a very short reach insert, basically only the bottom half of the threads are in the helicoil insert, so I believe it to be 2T oil making its way through the threads under compression....OR it could be a leaking crank seal, my right exhaust does seem to smoke a little more than the left :-[
Secondly, the L/H plug fouled out at first and was reading way rich versus the R/H plug.
I replaced it mid-ride and ended home with this. It is still richer than the right, it looks.
WHAT could cause one side to be richer than the other?
Especially the left side?
Both carbs have the exact same settings at the moment.
5DP7/4th clip down, 190 mains, crossover, Dave mod, Uni and Y boot.
If it was a bad crank seal, I believe it would just suck in extra air instead of transmission oil...
so yeah, i will try 185s I believe.
