I have 24mm for the OD of the front axle sleeve nut ??????
doc_rot said:i wont be home for at least another week and a half
doc_rot said:You need 8 studs of 2 different lengths. . The 1000 uses 12 studs of three different lengths, so if you buy the 1000 stud set you end up with 4 studs that are too short. APE might sell you a stud kit, sans the 4 studs you don’t need but demand is virtually non existent for something like this so I would be surprised if they would. You also need their longer head nuts or through nuts to compensate for the slightly longer head studs. Their contact info is at http://www.aperaceparts.com/
Maritime said:But if you give them permission to put pictures on their site etc of your bike with the blower and their studs holding in the pressure that's some great marketing material.
doc_rot said:I still haven't found my engine parts in the garage yet. However I picked up a spare motor today that I broke down last year that has been at a friends shop until now. I also saw the incorrect stud length listed in the cross reference and knew it to be wrong, but since they are the same studs for the 1000 I figured they would fit.
Stud lengths are 190mm & 180mm
canyoncarver said:I'd buy a set.
beachcomber said:Just a thought - were the APE studs you bought all the same length ?
