Honda CB466F Barely Legal Track Bike "Goldie"
Re: Honda CB400F Track/Street Bike "Goldie"
Just waiting on one needle bearing for the starter gear and then the cases will be put back together and I'll get the top end going. The crank was lightened and balanced by ape. Rods were shot peened and balanced by Mike and he put cb750 rod bolts and nuts on for added strength
Wrapping up wheels and tires tomorrow. Threw on the forks so I can get an idea of I'm going f to polish the lowers or powder coat them satin black.
Alright front wheel is done except for waiting on my 20mm axle from ttr. Rear wheel I'm gonna have to angle the spoke holes more. When trueing them, out too much of a bow on the spokes. Bucannon said it was structurally good but I didn't like how it looked.
So on a different note, bottom end is done. Got my ape studs in and going to do pistons tonight and hopefully get the cylinders on.
Got the cylinders on.
Well the motor is officially in! Gonna glass the seat pan and then get back on the tank and tail fairing
My last package from ttr400 showed up. As always, outstanding work from Kevin!
Well couldn't help myself. I polished the motor mounts and brake stay. Also just set my tappet covers and points cover on.
Got my starter and oil pump on tonight. Started on cutting the fat off the sprocket cover. Also got round one on my seat pan done.
Alright got to where I'm happy with the sprocket cover. It's going to get vapor blasted like the rest of the motor is. The holes I spaced around the structural bracing on the backside. I'm happy with how it turned out. Also did the last layers for the seat pan. Going to trim it tomorrow and put some nut serts in it and off to Chicago to get some leather and alcantara
Seat pan is done and off to Chicago
Quick update. Side covers went out today to vapor-blasting.net, seat pan went out also. My shocks should be here today or tomorrow and my head arrives Wednesday. Last night finally got around to cleaning the shop before I get back on the cb175.
Oh ya on the plus side, I got shocks!!! I'm torn on the fork lowers. I was thinking polished but then I bomb canned one black quick and it looked pretty damn good.
Triples are going on tomorrow and I'll begin work to mount my led headlight.
Oh ya a piece of art arrived today. My stage 2 ported head from the man, the myth, the legend, MRieck
Head is on and torqued down!
Got alot done tonight. Polished my triples and upper fork legs. And mounted them with tapered bearings. Also got the tank and tail into primer.
Blocked the tank and tail. Blocked out very nice. Going to do one more round of primer and then ready for paint in a week.
Last round of primer is going on tonight. Picked up the last of powdercoat parts. Also got the clutch side togther. Went with ebc clutch
Front end is mocked up. Gold valves will be here this week and I'll get the forks back together. Also last round of primer.
Got my preload adjusters from ttr400. Wet sanding primer Friday and planning to paint Monday.
