Can I diy the spacer for the fork? Ooracing fork upgrade costy to ship to singapore.. any alternative way?stroker crazy said:I am happy with just the spacers for the time being. Perhaps I will use a heavier oil in the future, but the 30W seems too heavy to me.
At 67kg you certainly have a weight advantage! Some other 'Ace' riders would be nearly double that.
Crazy
joeylimzy said:any alternative way?
i guess i need to see some photo..stroker crazy said:DIY easy!
A 10mm x 25mm hex bolt, two nuts with a spring washer between.
Tighten it all up and you have an object 19.25mm in diameter (across the diagonal) and 24.60mm long (flat to flat).
Insert in fork head up and refit fork cap.
If this doesn't make sense, I can post a photo.
Crazy
joeylimzy said:i guess i need to see some photo..
stroker crazy said:The threaded end goes into the centre of the spring, and the fork cap bears against the bolt head:
It might be crude, but it's effective!
Crazy
Sorry .. jus want to double confirm about the size .. which is the length of the screw and which is the size?stroker crazy said:The threaded end goes into the centre of the spring, and the fork cap bears against the bolt head:
Crazy
joeylimzy said:what size of iridium spark plug fits ace?
orrible-64 said:motorcycle trader...letters to the editor...
Thanks so much .. will proceed to get 1 from ebaystroker crazy said:I've found the NGK DPR9EIX satisfactory, although the NGK DPR8EIX should be fine also.
Crazy
orrible-64 said:a rear wheel pit stand
good reason to get a custom plateChrisBNE said:Fuckin number plate fell off.
sprocket2cog said:good reason to get a custom plate
