GL500 Silverwing Scooped for $125
Working on the bike again after a long pause
Welding therace didn't work for me... but it did give me a place to get some grip and work it out after 10 minutes of carefully prying back and forth.
I ordered the Incognito steering stem to mate the GSXR forks to the Silverwing frame
And started sandblasting the frame at lunch today.
I'll be working the Porsche Rennsport Renion next week so no progress will be made on the bike
Sent from my XT1635-01 using DO THE TON mobile app
I pressed the Suzuki stem out and the new stem in. It's a very nice piece with great machine work & precise tolerances... it went in smoothly didn't complain at all.
Also primered some pieces at lunchtime
Sandblasting is fun for five minutes.. then the fun stops.
Another hour of sandblasting... it never ends
Yes. Save the blaster for those little crannies that you can't get a scraper/wire brush/scrubber into. And wear heavy rubber gloves!
Thanks guys, can you recommend a stripper?
Lunchtime progress, the first few bits painted & clear coated:
Aircraft Paint Remover (brand not important). Any big box home improvement store will have it. Read and follow the instructions!
rustoleum aircraft remover its a spray
goofy name but good product
comes in spray cans
https://www.rustoleum.com/product-catalog/consumer-brands/auto/removers-and-chemicals/aircraft-remover/
quarts and gallons wear gloves it bites
Jasco spray is the best.
http://www.jasco-help.com/product/premium-paint-epoxy-remover-aerosol
Jasco in the can is 2nd choice.
For what its worth, I used this stuff to remove POR-15 from the tank on my 360
Found a clean CBR600 rear coilover w/ remote resivoir to replace the factory Sliverwing air shock... only $50 shipped.
The coilover is less than a centimeter longer that the air shock w/ same diameter mounting bolts.
Also making plugs to reinforce new seat joints.
Latest progress includes sandblasting the swingarm, painting it, and installing the bearing race.
Then even more sandblasting of the frame. I probably have at least 5 hours of blasting this stinkin' frame. Yesterday's lunchtime consisted of prepping the frame, then today was a great day between rainstorms to lay some primer on it.
Next is some basic assembly to begin seat tube fabrication.
Hopefully next week I can do some loose assembly of the GSXR front end
