LED Headlight with harness
epidemiks
The $100 LED headlight option with the harness - Is this an actual headlight, or just additional wiring/electrical bits to allow for a headlight? Cheers!
Actual headlight and the wiring (since most LED headlights don't use standard connectors). Hang tight though. We're getting ready to reprice them as the costs of LEDs are dropping.
nice!
any chance of a pic of the headlight? I assume it's E marked?
probably around 1-2 months away from dropping some coin on rewiring, so no hurry.
We're actually swapping over from a complete headlight to an LED insert. This allows you to use an H4 compatible bucket that you would like.
Very bright and pulls less than 20W.
Pic attached of one on my bike shining down my 100ft driveway.
Are you selling the inserts individually at all? I'm looking all over amazon, but nobody reputable ships to Canada. Need a reg/rec anyways from you, maybe I can get both at once.
Just using the terminology you used earlier. I guess I mean the H4 led bulb with any required driver etc...
A la: http://www.amazon.com/6000LM-Xenon-White-Headlight-Motorcycle/dp/B00PQH7YUG/ref=sr_1_1?ie=UTF8&qid=1422893607&sr=8-1&keywords=h4+60w+cree+headlight+led
Hoping to very soon, but not just yet. I have some samples arriving from a manufacturer in the next couple of weeks. If they work out, I'll place an order with them to get some in stock.
Looking forward to it. On another note, I can't sign up on your site, so is e-mail preferable?
You can't sign up on the site? Is there an issue?
But yeah... email works, too.
info@sparckmoto.com
Everytime I try, it tells me to use the standard 2-letter code for USA, even though I select Canada, and then it reverts me back to USA. I can PM you if you prefer. Sorry to have taken over this thread.
Thanks for the heads up.
If you email me your details I'll get you into the system and take a look at the issue.
