I need guidance on swapping a 19" front wheel onto a 74 cb360 disc brake. I was told cb500t works, got a wheel, new bearings, rotor, and new tire and tube. First problem is it requires different spacers than stock wheel, no problem I can make those easy. Second issue is the cb500 rotor measures 10.75" and is 6 bolt. The 360 rotor is 10" and 4 bolt. If anyone has done this swap and cares to share info please let me know. Otherwise I guess I will be turning the rotor down 3/4" to fit.
