racing geek
Just a kid with a welder
I put one of the later air-cooled 16 valve GS750 engines in my CL360 but the stock 32mm carbs don't fit. I've been told that 34mm carbs are a good upgrade but those also wouldn't fit. I plan to make some 2-1 intake manifolds and run two carbs to feed the four cylinders. I'm not sure what size carbs I would need though.
I did some quick math a couple nights ago based on the 9,000rpm redline and found that a pair of 38mm carbs would be ideal. However I was told by an engine builder on another forum that 36mm carbs would be the way to go since I mentioned it would be a daily rider. Any GS or carb experts have some input?
