www.townmoto.com
www.Moto-Madness.com
Author Topic: The SkyTeam 'Ace' Resource  (Read 471849 times)
Offline Sneikz
Skyteam chain lifespan - Replacement
« Reply #2620 on: Jul 28, 2017, 20:59:49 »
Had a couple of wet runs over the last couple of weeks and that killed the chain. It was the original which is not an O ring. As previously mentioned it had done just on 10,000kms. I was surprised to see the rusty dry pins when removed, even though it was well greased. A good rule of thumb for replacement is that if you can see daylight when pulling off sprocket, it's time to change. Sprockets are still in good nick.
I was able to again turn a 10 minute job into half an hour. 15 minutes of that was attempting to clean my hands afterwards! Note to self - Wear disposable gloves next time!
The Silver Bullet Thread: http://www.dotheton.com/forum/index.php?topic=71205.0
Silver Bullet Pics: https://goo.gl/photos/EXyfM3K42BHp2D6w9
Aces on the net: https://goo.gl/c8QmjP
Silver Bullet mods booklet: https://goo.gl/97mGRI
Other Bikes:
2007 Suzuki Boulevard M50
2005 Tomos Revival (TS)
Live long and ride hard \\ //
Offline stroker crazy
  • crazy as a fox
Re: The SkyTeam 'Ace' Resource
« Reply #2621 on: Aug 23, 2017, 07:46:00 »
It's BOTM time!
Sneikz has voted, I've voted; give it a try (it's painless).
http://www.dotheton.com/forum/index.php?topic=74394.0;topicseen
Crazy
“Ride like the Wind” W.H.
  • crazy as a fox
« Reply #2622 on: Aug 26, 2017, 23:39:07 »
Great news from Michael at Skyteam Canberra & NSW!
Check it out on FB: https://www.facebook.com/skyteamcanberra/timeline
  • crazy as a fox
« Reply #2623 on: Aug 28, 2017, 21:40:04 »
More goodies from Michael at Skyteam Canberra & NSW!
Both are 330mm in length.
From Mad Monk in Thailand at $115.00 the pair + postage.
and Kitaco from Japan, at $215.00 the pair + postage.
More info at: https://www.facebook.com/skyteamcanberra/timeline
Offline 2b
« Reply #2624 on: Nov 11, 2017, 03:39:05 »
Finally putting my Skyteam Ace 125 => 150 back together. Have been too busy riding my big bike, so the Ace has sat for months with piston rod waiting for the new 150cc piston and cylinder.
I didn't take photos when I disassembled, damn it. Not overly sure that I have got the dowels right. Pictures in CG manual and on the web for the Ace don't agree and the sketch I made is different again. The sketch  shows two dowels at base of cylinder, both on the push rod side. And two dowels between cylinder and head diagonally opposed, with front one on the push rod side.
How many dowels should I have below the cylinder? In what position? And should one of them have an O Ring?
How many dowels between cylinder and head and in what position?
And finally if I haven't got it right what risks do I run??
Cheers
Richard
« Last Edit: Nov 11, 2017, 03:56:17 by 2b »
He's obsessed with order and clarity. He doesn't like mess.
Harold Pinter
Build thread: http://www.dotheton.com/forum/index.php?topic=61167.msg694438#msg694438
  • crazy as a fox
« Reply #2625 on: Nov 11, 2017, 04:31:06 »
Not overly sure that I have got the dowels right …
Unfortunately I didn't keep a record!
Don't remember any o-rings; the head seems right:
Offline alex-i-oh
« Reply #2626 on: Dec 07, 2017, 09:06:11 »
Cheers
Richard
Hey Richard. I have done the 150cc conversion and I took loads of photos! Can send you what you need if you pm your email.
Alex
Offline 2b
« Reply #2627 on: Dec 07, 2017, 13:32:24 »
Alex
Thanks Alex,
I am all done. It is running great.
Harold Pinter
Offline alex-i-oh
« Reply #2628 on: Dec 07, 2017, 19:09:42 »
Ah no worries, well done for getting it all sorted. How's she running? What carb/ jetting are you using if you don't mind me asking? And what did you set your valve clearances at?
Al
Offline 2b
« Reply #2629 on: Dec 07, 2017, 21:53:00 »
When I first got the bike I got rid of the EGR stuff, changed to OO Racing header and emgo reverse cone muffler with two stroke packing. At that point I rejetted the standard carb. Jets 100 Keihin, 48 OO Racing
For this 150 upgrade, I re-used the 125cc head as I had heard that is a better way to go. So effectively I just swapped out the barrel, piston, rings and gudgeon pin.
Valve clearances as stated in the manual .05mm. I do that a bit tight on intake and a bit loose on exhaust.
I will do the CDI and carb (and probably pod filter) later. Will get whatever Skyteam Canberra reckon is the latest and greatest when I get around to that.
If you want to know about what others have done, take a look on here...
https://docs.google.com/spreadsheets/d/1USvziYIyzfyxfZA1YYpQf9eP4djb0GLWbvWcmME88Gk/edit#gid=0
Cheers
Richard
Harold Pinter
