MCKAY34 said:Yeah im just have a play around with it now, its becoming very annoying. and i really am struggling to find a way to install it where it wont rub the tire too much.
also all the information/instructions they sent are in german, so that is a huge help, considering i dont speak german, so most of the bolts etc i have no idea what they are for.
Mounting it i can already tell is going to be a challenge.
Haha thanks mate, I have asked kedo to send me the English instructions. Still waiting.CrabsAndCylinders said:You could also type the German instructions into Google and translate. They won't be exact but might help. Just don't mention the war.
Mr Bernzo said:Love it. Looks great. As for starting it, fuel, choke, then start kicking!
Sent from my Moto G Play using Tapatalk
MCKAY34 said:Thanks Mate, wanted to go into a bit more detail than that hahah.
I have been kicking but no luck, time for some troubleshooting.
CrabsAndCylinders said:Keep the throttle closed when starting.
I like to keep it simple. It's a big single 4 stroke. It's not going to be fun to kick over. If you have good spark, fuel & air flow, ignition timing set correctly, valve timing correct then you should be good to go. Make sure that the piston is at top dead centre before kicking.MCKAY34 said:Thanks Mate, wanted to go into a bit more detail than that hahah.
MCKAY34 said:ok ive been kicking and kicking, something is up.
Take a look at my points plate, while on the F mark.
any thoughts, or any opinions on what else i should check or adjust,
I have spark and fuel
