So, I am not dead. I haven't forgot about this project. I just got side tracked for a while. Working on getting this thing finished up so my wife can learn to ride on it this spring. I ordered some more parts, a seat from Texavina, and we are getting close. I'm working on putting the rear brake back together but have ran into some issues. I took this thing apart 3 years ago so memory is pretty slim on it and my clymers manual is all but worthless.
I have the pedal mounted, with the cam going through, and the spring sits under the pedal arm and then the upper tab of the spring goes to the tab on the frame. The tab coming off the frame is bent back at maybe a 30* angle. Is this how it is supposed to be? The few pictures I found of this area it looked like that tab was straight, but the is a thick piece of metal and I don't think it was bent accidentally. With it being bent at this angle, the little adjuster screw does not come into contact with the pedal, so I can't really adjust the pedal height. There are two threaded holes in this bracket/tab, neither really lines up right with the pedal. What am I missing? Also, anywhere I can get a non rusty spring? I also lost the bolt that goes into the cam, so gotta go to the hardware store and hunt one down that will work.
Lastly, is the little hook/loop thing just to be used as a guide for a vent/overflow tube off of the carbs?
