Hi all,
Last year I unfortunately blew a hold in one of the pistons of my CL175. Have just rebuilt the top end, new pistons +0.50 rebore & new valves.
Started the engine up & she runs. Have been going through the break-in routine however there's a few issues that I'm having.
Main issue is that the bike won't hold an idle. Have set the the mixture screw on the carb to spec and once the bike's kicked over it will run & idle correctly for about a minute or so then it will slowly drop in revs and cut out. This will also happen when I'm slowing down for a stop sign/traffic light etc. I can keep it at idle speed by applying slight throttle. It seems that the idle screws aren't making any difference at all. I can't seem to raise or lower the idle by turning them.
Second issue is that the bike doesn't seem to have any low down power. It will ride okay until about 3-3500RPM where it will hit a powerband & take off. I'm confident my timing is correct however I'm wondering if it could be an advancer issue? Also been told that this may be normal for a freshly built engine.
Any thoughts suggestions appreciated! Would rather try do what I can myself before consulting a professional.
Cheers!
Cheers!
