HiroProtagonist
Hey All!
I've put together rear sets much like these:
http://www.dotheton.com/forum/index.php?topic=7401.0
http://www.dotheton.com/forum/index.php?topic=7970.15
and they're working great. The only issue is that, as my bike is a CX500, I need a way to change the direction of the force.
All is working great, except that the ball bearing on the linkage isn't holding the best. At first it popped off pretty easily when I was downshifting (just weakened over time), so I used jb-weld (kwik-weld) to build up a bit of a wall around it to stop it falling out. This held quite well until the bike almost took a spill, and my foot must have kicked it, and off it popped. SO, I'm trying to figure out a better way of seating the bearing, or a better way of setting up the linkage (to not put so much directional force). I can obviously use real jb-weld, but I'm still feeling that this isn't up to the task, and trying to figure out if there's an alternative.
I have spare aluminum stock (1/4" 6061), so I can make a different form of linkage, and I'm open to any ideas.
I know this is a noob question and there's probably a perfect thing built just for this purpose. Thank you all! My shitty picture of my current setup is below:
