cl 360 wont start
bobfrk
hey im doing a cl 360 bobber and im having a little trouble getting it running. does anyone know what the points should be set at? i know i need to kit the carbs also but i tryed to fire it by squirting a little gas in the carbs (also with fuel in the tank) and the best i could get was fire out the pipes. im also pretty sure i need exhaust flange gaskets as the pipes move around even after i tightned the flanges, possible cause of the fire out the pipes? i dont mess with bike motors very much and im kinda stumped. any advice anyone has would be appriciated. thanks
I believe the points clearance is .012" - .016", is that what you are looking for?
What all have you done as far as maintaining it? Compression test, timing, adjusted valves, etc? Any one of those can prevent it from firing up.
