bryanjoh
So I've been doing a Virago cafe build over the past couple months and am now on the tail end of things. See build thread here,
http://www.dotheton.com/forum/index.php?topic=64897.0
I started shortening cables the other night, but when I got to the clutch cable, I came to realize that the lever arm that the cable pulls on the left case will not pull.
Now, I had the left case off a while ago when I was replacing the starter gear (see build thread if needed, top bit of page 1), and I am assuming I messed something up when reinstalling the case cover which contains this lever arm assembly. I would like to avoid pulling the case off again, as it was a bitch to get back on the first time, especially with liquid gasket.
Does anybody know what may be causing this lever arm to refuse to rotate at all or has experienced this?
Thanks,
Bryan
Thanks,
Bryan
