XS1100 I got for $73
DesmoBro
Busted Nut
The Lady wanted $75 but I only had $80 or $73....and I smashed out the back side window of the car loading it in, sooo I think she felt Pity on my soul....but everything on it is Seized and they took the front wheel off to make it easy on me....A few Days after Dragging it home she emailed me saying they found the title....going to try and get this thing turned around fast( but you know how that goes) anyways this bike came with 95 hp stock so im curious to see if I can get that up around 100 with some mild upgrades....that is all contigent upon if i can get it to run....but if its going to run im gonna want to ride it so i want the brakes need to work but after taking those apart and waiting for pads i wanted the fork tubes to be pretty but before putting them back together it needs new seals and boots....and its going to be warm for 2 days starting tomorrow so this needs disassembly tape/ primer& paint astat
That was a bit of a ramble and probably didnt make much sense ....life is a puzzle ....Get Some....
....oh yea.... And mid summer I got a Parts XS1100 for Free....tore that one down pretty good tho going to keep some goods from it like the kick start.....
they do go like hell lol
mine started not far from yours
keep at its worth it
nb the front forks are like lip noodles even with a fork brace
now that i have decided i like mine i a going to swap the front end
...good to hear im not the only one on this boat....front forks would be nice ....maybe if this parts motor sells....
here is what mine is looking like now i was driving it for the summer now that winter is here it getting a gl650 modded front end
dual discs dual calipers stainless steel brake lines
painted and new seat pad
and i have to talk to deviant about some custom metal side covers
There is a shop in Spain that has done a couple of XS1100's. I'm inspired by what they've done.
I ride a stock Special. The front end is fitted with upgraded springs, Race Tech emulators, and a TKAT fork brace. It gets around the turns just fine. There's plenty of help with the basic bike at XS11.com.
Cxman that Mountain of front fairings is awesome!...and im going to try and not paint the motor on this one....
i weigh just over 250 geared up and ride like a moron a lot so the front end even with the t kat brace i have sucks
god help you if you have to brake in a corner !!!
btw desmo if you want the fork brace i will be pulling it off in a few weeks
I have a 100% torn down 1100 in my garage if you need any motor or tranny parts....brakes, front end, rear end...basically everything. I was going to ebay it all off but don't have the time. I'll get you best prices for anything you need.
Hey Desmo,
I'm sure you've seen my 11 by now. Im from Andover if you need any help with this thing. I've been around the XS11 for about 6 years. Fast as hell when the carbs are right, They hate pod filters
Yep. It takes more than a fork brace.
How did you jet yours? .....im going to be running K&N Pods with a 4 into 1.....Both Master cylinders i have are fucked i found one from an old ninja 600 which seems to be working testing my calipers now so i know if i will need new ones .....lots of parts off.... Lots more to go.....
Start with stock jetting. You can make changes when and if necessary. Stock mains were 110 all the way across. Pilot jets are 42.5. Tuning with pods might be a little challenging. I'm assuming the carburetors are the original ones that came with the 1980 Special. There was a significant change in carburetors between the 1979 and 1980 model. Also, there were subtle differences in jetting and needles between the standard and Special models.
i have a few sets of spare stock carbs if you need some parts i dont use them
you can get a lot of specific info on the xs site
but be ready for the oh my god you cant run pods crowd
and make sure your ignition and advance is working correctly before making any sudden moves
You just need to buy the K&N Ovals and make sure they don't block any of the vacuum passages. I don't know my Jetting as I had them sent out and base tuned to my Intake/Exhaust. It runs fine and fast, has a little flutter at times on hard accell but it isn't a problem when its dialed. It will in fact run like absolute shit with the Ebay pods, and I assure you I'm not one of the "oh my god you cant run pods crowd", I'm one of the "I've put 25k on a modified XS11 and they do not take well to intake changes unless you actually take the time to compensate and tune it" crowd.
Save that girl. i've also got a lot of 11 parts local if you need anything
make sure you do good tires and put your time in on your brake YOU WILL NEED THEM
