That's probably what I'll do. It's what I did to ride it around last weekend.Brodie said:Why not sandwich the element between two screens. Looks good man.
irk miller said:Making some tweaks to the carb kit to get fitment with this frame. I couldn’t get enough clearance either inbound or outbound to get an air cleaner on the carbs, so I put the flange side down on the intakes to a belt sander and ground an angle to each side, then followed up with oil and sandpaper on a surface plate. The K&N style filters still don’t fit, so we’ll make our own. The plan is to add a Uni element under the screen, but I have to secure it to keep it from getting sucked into the carb.
It's etched aluminum.trek97 said:Just how in the F did you do that?
Thanks, my man.canyoncarver said:That is beautiful.
Circuit board etching solution is ferric chloride. I do use that on copper etching plates in printmaking. This is a saline etch: copper sulfate and salt.JustinLonghorn said:Printed Circuit Board etching solution?
