Honda NSR125 JC22 disc options
NoRiders
Over 1,000 Posts
So, after a good few hours browsing various Honda model discs I think I might've found a workable alternative disc that meets the requirement.
The requirement being I need a disc with a 5mm (approx) offset to allow the use of a bigger caliper and have wheel clearance. So, looking for an alternative disc to fir the NSR wheel hub.
A CBR250 could be it.
The centre mounting looks likely to be the same as the NSR disc mount I reckon?
The NSR disc measure PCD 12mm hole to hole and the centre bore 10.5mm with what looks like a 5mm offset. I'm not too bothered about the diameter as that can be allowed for when mounting the Brembo.
Don't suppose anyone has a definitive answer out there? Cheers Colin
A simple google search for 120mm PCD Honda disc turned up an ebay item with 55 mins to run....CB750SOHCfront/GL1000rear disc looks to be the ticket :)
I await delivery with baited breath.
