DreadRock said:Hey rich when you get time can you give me the axle size for that wheel ? I'm looking to put GSXR wheels on the FJ and was told a bandit wheel is the same . I think the rotors are 320mm and that it has a mechanical speedo drive correct ?
Joe Suzuki said:Later Bandits and RF900's had vertical bolts and fork braces, so don't know, maybe yours is an early one. And maybe back then they thought the fender was enough? At any rate, make sure you get some vertical section welded across there (maybe some .100" x 1/2" flat bar in an "X" pattern between the hex spacers), otherwise just having that plate across won't do much, it will just flex.
Big Rich said:Here ya go Ben:
http://www.partzilla.com/parts/search/Suzuki/Motorcycle/2001/GSF1200/FRONT+DAMPER/parts.html
I can't remember the years, but I think it was from 01-05 they used these forks on the Bandit 1200.
Maritime said:Nice work so far Rich, I would do something like this on the brace.
Joe Suzuki said:That's exactly what I was thinking of.
