stroker crazy
crazy as a fox
Re: the 'Ace'
Also my reaction!
Crazy
mikeyw64 said:… felt like there was nothing in the box!!
Also my reaction!
Crazy
ChrisBNE said:there is a service due …
ChrisBNE said:Opening her up and checking valves....
kwando said:Have received (kind of) permission from the boss .
stroker crazy said:I've been using Shell 20W-50.
Crazy
stroker crazy said:I did the first change at about 150k and roughly at 500k intervals since. Now that it's covered 3000k the interval will be extended.
Saving on oil is no saving!
After the first time, checking clearances takes less than half an hour. Incorrectly adjusted tappets causes engine wear/damage and power loss. If you require information on the procedure, let us know.
Crazy
stroker crazy said:Just regular stuff - I'm not organised enough to get to the bike shop before I think of doing an oil change!
Crazy
Just Dan said:It is a good thing to check the tappet clearance at 100 km as the user manual states. I seen a couple new ACE's now and they all seem to be shipped with no valve clearance at all.
Adjusting the vales might sound hard, You can download a PDF for a honda CG125 workshop manual. This explains with pics on how to do this. After you done it once, you wonder what the fuss was all about.
ChrisBNE said:Do I need to buy a torque wrench for when I put the cover back on?
Sent from my iPhone using Tapatalk - now Free
sprocket2cog said:… you could replace the bolts with new ones of a better quality …
