Not that I can tell. The forks are just a little shorter, but because it's not a leading axle, and I'm going to be putting actual handlebars on it instead of OEM clipons, it's right about at the same height. I forgot to measure the clearance before I tore the thing apart. It's probably slightly higher because of the much larger tires.fjm5341 said:
verboten1 said:Thanks, this is off the shelf, and if I go making anything it will be a higher exhaust, more fitting for a scrambler. Right now it's just kind of sitting there, so I'm not sure that is the correct position. And it's only on the one side, it's a 2-1 exhaust.
Sent from my Nexus 6 using Tapatalk
