1980 XT500 BUILD
MCKAY34 said:
Hi guys, well because the response was so fast and i solved the issue in regards to my last problem. im going to see if we can now fix this problem.
Does anyone know what these wires are for?
They are at the headlight end. I need to know what the 4 in my hand do. and also the 6 in the connection individually. I think the connection is for the handlebar switch block. But i need to know which wire does what.
Again any help would be great.
Found a wiring diagram that might help:
Yellow = hi beam indicator light
Blue = tachometer lamp
Green/Yellow = front brake switch
Blue/Red = pilot lamp (in headlight)
thanks for your help mate, i have this diagram also, its not correct with my wiring loom. also the brake switch wires are accounted for.
The bulb connectors prongs should be labeled if you pull the connector
Nah they arnt, but that's ok I solved the issue of the bulb wires. I just tested it on the battery so now I know what wires do what for the bulb.
Sorry everyone I should have done that in the first place.
I'm still stuck with all the other wires.
Rather than me throwing hammers in the garage because i cant figure out the wiring,
i have started to make a small bracket to hold the speedo.
Just installed the rear brake switch, i was waiting for the bracket that holds the brake switch,
I installed that bracket i made for the new speedo, its sits perfect, clean and low. pretty happy with it.
I have been trying to buy a new rear brake arm for the rear drum break, because the one i have is destroyed, i havnt had any luck buying a new one, so i am going to have to try and fix this one i have.
the rear brake arm worked out ok, after a few hits with the hammer and the angle grinder. I slapped some new paint on there, and bought a new spring. looks ok and im sure it will work great!
What are your thoughts?
Looks good. You followed the tried and true method of hammers and angle grinders. If you start there you cant go wrong. The hubs, spokes and rim combination looks great.
Sent from my Moto G Play using Tapatalk
Probably the biggest challenge i have had so far is redoing all the wiring, given the way the wiring was, i will feel so much more comfortable rewiring the entire bike. knowing that every connection and wire is solid and connected properly will make me feel way better.
Most of my delay with my posts have been because i have been trying to figure out the wiring, but I have made some great progress understanding the wiring. So im kicking goals now!
Looks like good quality environmental splices there.
One thing you'll find, like I did, is the Hi beam indicator on that speedo is BRIGHT! So much so, that I put a piece of tape on it at night, because it kills my night vision!
Sent from my SM-G955U using Tapatalk
Yeah your right, it is super bright, i have the exact same speedo on my Triumph.
Haha yeah thanks mate, I feel there is nothing that can’t be solved with an angle grinder and hammer!!!
Its always awesome when the last person that owned the bike just thought it was a super idea to weld the clutch foot lever on.
Great for him but a nightmare for me, trying to get it off was a killer.
Installing the new one turned out ok though.
I popped in the engine! woooooooooo getting exciting now.
What does everyone think so far?
I put the oil pan back on. If you flick back to the start and see the oil pan when i first took it off. man what a difference!!!
