1972 CB100 Honda..maybe for the wife.
Dayyyyum............that small sprocket is 30 bux and a chain 50 bux at the S & T.
Over 100 bux if I got the rear one with it.
This little bike is costing a bunch.
Yea, after posting that I thought about it............asked myself that very question.
Oh well.
It'll get to where I want it....................been this long, what's a few more months.
Im on board w all that.
But wife was looking at this sort of thing. 10-15 years old and just gross looking.
My budget hasnt hit $1400 mark yet. And the 100 has a coolness factor...for me anyways.
^^^^^^^^^^^^^^^^^^^^^^ewwwwwwww......!!!!!!!!!^^^^^^^^^^^^^^^^^^
Actually this is what my wife wants:
Well If were going so far as to finance something. Ill take one of those for myself + the wife would love to ride in a sidecar more than anything.
No financing gonna happen anytime soon, so guess she's stuck with waiting for me to get this little CB100 going. :eek:
Weeellllllllll ::)......maybe when I hit the lottery. 8)
You could always give her your 750. I bet that 100 would get done super fast if that happened
hahaha......she doesn't like it, cause she thinks all the bikes I have are too tall, or too heavy.
I keep trying to convince her she needs the softail, and I need a Ultra Classic.
Well, ordered the sprocket and chain.
Got a kicker shaft and lever coming from member 45exmayor.
Still waiting for the wire harness, too.
Played with the kicker I have currently, and got it running again......played with the carb needles......think I screwed it up more.
Got it to idle on it's own. But, not sure if it's right or not, gotta wait till the stuff comes in, so I can ride it.
Don't want to let it idle too, too long. Don't want to overheat it.
With newly rebuilt engine, don't want to over throttle it either. So, guess I still have a ways to go.
Darn little thing bite me too. All these bikes I have and never have been burned by the exhaust, but this little booger got me.
Damit man......that hurts.
Also got the daughter's car fixed.....found it had a broken wire on the injector harness.....................330 bux later, she's up and running the hour to work and hour back.
good you got it. $330 sucks.
I just took my Honda Fit to get a leaking tire repaired this morning...had to order 2 new tires for it. Cords are almost showing! That was the leak. Ugh.
Received the front sprocket, installed it................seems a little loosey-goosey.
Is that normal?
Also got the kicker shaft and lever from 45exmayor, gonna try to get that thing changed in a weekend, once the gasket set gets here.
In the meantime I'm gonna try some off the wall crap to tighten the one i have on the shaft just to try and kick it.
I don't have a gas tank, so push starting it won't work either.
My gas source is a 2 gallon tank with a hose attached from it to the carb. I will also try to figure out a temp tank source so i can ride it around the hood.
Have you checked with Gt550guy? He's selling a bunch of stuff, might have a tank you could use. Go over and check his selling thread.
The sprockets do a bit of wiggling on both my bikes. Seems normal enough.
Is that normal?
Is there enough room to shim it? My stock CB750 sprocket is not loose, but the one I got from Sprocket Specialists is 2mm narrower at the shaft. I got a pack of generator shims for VWs to shim it and make it tight.
Thanks guys.
We'll see what happens when the chain comes in.
Got links for those shims?
Got some mo' new parts for the little CB:
Front sprocket
Chain
Wire harness.
