1979 KZ400 LTD: finally done!
Re: 1979 KZ400 LTD
Still going! A few updates over the past few weeks...
Upholsterer finished with my seat....I'm so anxious to get it back, hopefully by Wednesday.
Cut some steel for clipon handlebars to replace the aluminum that came with the set. Brushed it, and drilled for internal wiring.
Quickly fabricated a small aluminum mount for the headlight, to figure out mounting height and angle. I'll probably redo it a bit better later or have one welded with a little stem off the lower triple and skip that big mounting block that comes with it for Harleys.
Re: 1979 KZ400 LTD
killer build mate....
i love what youve done with the wiring in the clipons.... may have to copy that one!
im doing a kz750 which has a similar shaped frame....i chose not to cafe due too the shape of the frame,
but you sir have done a great job on the rear!
looks like a cafe for sure
Re: 1979 KZ400 LTD
M.B Co said:
Nice build and great idea's. I am doing a crap tastic LTD as well.
Thanks! Yours looks awesome, great work! That LTD frame is so hard to figure out a custom seat, but if you can do a pan that keeps the seat height flat and only the upholstery looks like it's dropping to match the frame it could look pretty cool without welding a whole new rear end. Like this: http://www.motomucci.com/2011/10/project-cx-full-shoot.html
If I didn't have a friend that had the skills, equipment and time I would have gone that route.
How loud is your twin with no mufflers? Like crazy make-all-the-neighbors-hate-you kind of loud?
Re: 1979 KZ400 LTD
I finally got my seat back from the upholsterer, and painted the seat shell. It's cleared with Eastwood satin, not sure I love it but I'll go with it for now...the bare metal looks better in matte than the painted areas.
The brown leather ended up the perfect color, and it's super soft and comfortable (considering it's only 1" thick"). The leather is actually from a Fisker Karma, leftovers from a prototype interior....super high quality, very blessed with that hookup.
Re: 1979 KZ400 LTD
It looks great! can you shoot a side shot of the bike? My bike is very similar..even with the same style seat. Im trying to see how you pulled the area where the seat base and the point of the tank together.
Re: 1979 KZ400 LTD
I'm going to work on it a bit more tonight and get it out of the garage for some shots with a real camera.
The tank uses the original mounting point, and the trailing edge of the tank sits a few mm above the fiberglass shell, the foam/leather pad is flush right up to the tank.
Re: 1979 KZ400 LTD
thanks, i would love to see a better shot. I have a kz650, and you might be able to see in my avatar what im talking about. the lower part of the seat pan on mine has a weird edge where they meet and I have been racking my brain to see what angles I need to make to make it look better. Yours seems made similar, but doesnt have that issue.
Re: 1979 KZ400 LTD
Here are some shots from this evening, finally outside in better light with a real camera
Re: 1979 KZ400 LTD
Thanks man, it's a chore for sure to make these look clean and nice. I don't mind the step up. I may try to use it to my advantage to make a very slim brat style seat that goes up with the frame. But who knows, once started I may change my mind and re-hoop the rear to be flat.
It's loud, but not obnoxious IMO. It's going to get a tad louder but cleaner sound with the exhaust. Stock pipes to a 2-1 Collector and the stock muffler sectioned to be a megaphone style tip.
I live out in the country, so the open pipes are normal around here. Makes bombing country twistys much more fun 8)
Mock up of how it's going to be. During the mock up I ran it with both sides and tips tacked on and it sounded amazing IMO
Here is what it sounds like. This was it's early stage in life when I first got the bike
http://www.youtube.com/watch?v=SaMA8wbNuuc
Re: 1979 KZ400 LTD
dmrhoades said:
So what are you thinking on a tail/brake light?
Sorry for the blurry iphone photo...it's a chrome light wired through the shell. I think I'm going to brush it so it's not so bling bling, more like the tank and signals.
