XS750 Cafe Racer
This thing s going to be amazing. Can you tell me more about how you adapted the Triumph exhaust? Was a lot of fabrication needed to make it fit to the head of the XS?
sorry the pics are rubbish
The header pipes needed small collets fitted so the down pipes clamped tight into the head also the
holes in the collars needed opening up so that they lined up with the mounting holes
in the cylinder head
Lastly had some link pipes made
Also, where did you get your rear struts? How many MMs high are they? I was considering doing 335. only because I couldn't find any that were 340mm and wouldn't brake the bank.
This is going to a thing of beauty! I had no idea that you could polish the brake caliper, or have you had this chromed?
The rear shocks are 335mm between centres and were bought from
UK ebay (seller was turbogas I think) They cost £55 inc p&p
No parts have been chromed
Wiring put on today just the rear light to wire in
A bit of work done on the rear sets
Made a start cleaning up the sump and oil filter cover
Carbs, cables and brake lines fitted
Made a start on the rear sets
Exhaust nearly done
Managed to get a few more jobs done today
Brake side of rear sets finished
Brakes bled
Fabricated some mounting brackets for the seat
Tank and rear mudguard brackets finished
The engine took a while to get running I think
the carbs will take longer to set up than I'd hoped
Rear light rear sets finished
Played around with the carbs and the bike
seems to be running a lot better
Started rubbing the tank down with wet and dry
Spent the day polishing the tank
Still nowhere near finished
Front mudguard brackets made and fitted
