Got it "running" today. I throw the quotes on there because I could only get it to idle with the choke on, making it hard for me to sync the carbs. Tried to take it around the block and it was ok, definitely not tuned right an a little bit of clutch slip, then died and wouldn't start a block from home.
Pulled a plug and it looks fine, but it won't start again. seems like there's enough gas in the tank. Re-adjusted the clutch, so we will see how that works out. Battery is pretty sad from so much starting so I'll give it a little charge tonight. Seemed to be charging when it was "running" though.
