After throughly flushing the crank case with diesel to remove any bits of the thread cutting epicness unraveled.
We starting taking the 250 motor apart (gearing side) and switched out the 250 clutch basket and 250 primary to the 400 gearing parts.
250 pistons were replaced by 350 pistons,oh yeah, theres quite a size difference ;D ;D they are pretty fancy with a graphite coating.
Then it was time for a test fitment,how everything lined up,ports, quish were spot on.interesting because these pistons are LC Prox pistons, only a tang on the piston was removed.so no wild porting measures ( for now 8) ) just port matching.
I will use the stock bottom gasket with the copper ring as a top gasket. should I anneal the gasket before usage?
As for the studs, we tried to remove the 400 studs which are longer (longer stroke than the 350 and 250) and bring them to the right length but failed, then we tried the 250 studs without stock washers and it seems to hold up fine!
My friend was so kind a blasted the cylinders and heads after test fitment, I´m currently painting and restoring them, next weekend I will reassemble!
Next will :
-test fitting the DG chambers
-carb jetting-->Any ideas in which direction i should go?140 mains 25 idles are stock 350,i guess start crazy rich and work my way down...
-first start up with premix
sorry for being pic heavy!!!
thanks you guys for helping!
