Hello! I'm trying to see if anyone has recommendations on beefing up a CB750F DOHC engine. I'm having my engine overbored to 890cc's with Wiseco pistons and new sleeves. The crank is being balanced and has custom made Carrillo connecting rods to replace the originals. The valve springs, followers and retainers are being replaced with titanium from Kibblewhite, along with their seals. The charging system is gone and replaced with a super light version from CycleX. The cams were sent out to Webcam and redone for their #110 grind. A new exhaust will be made with parts from Cone Engineering. The oil filter and housing are gone, replaced with the CycleX block to run a cooler (I have an oil cooler from a CB900 but I'm not sure if I'll keep it and maybe use something newer).
The question is there anything I may be overlooking?
I'm not lightening the crank, only balancing. The local speed shop machinist said it really isn't worth the investment for this case.
I haven't bought a beefier cam chain or primary chain, I don't know if this is necessary.
I'm thinking of going with CR31 carbs but haven't made a purchase yet.
I don't know about bigger valves, if they're worth it.
Any advice or suggestions would be awesome. I'm learning everything I can as I go but I dread the thought of piecing this all together and having some small part thing fail and destroy the engine. Thanks for your help!
