cgguy09
1971 CB350 K3
Gents,
I'm back from the dead. Long story short, about six months ago oil stopped getting to my top end on my 71 CB350 K3, I was able to catch it before too much damage was done.. although it did destroy my cam and my point cover. (I have pics if you want to see the destruction). But now it appears I am back in the same place.
During my rebuild, I took the opportunity to bore out the cylinders (because I was getting blow by & white smoke out the breather tube) and paint the engine.
After dealing with idiots boring out my engine (supposed to do a .50 over...instead did a 1.0 over) I got back to assembling the engine. (Using compressed air) I blew out all the oil routes when piecing the girl back together. All of them seemed clear. I cleaned the oil pump and the screen. Then when I kicked the engine over, and it started up nice & loud. The first thing i checked was the oil hole on the top left side of the engine. No oil was coming out so stuck a thin paper towel in there & it cam out clean. (I had the engine at 4k RPM). At this point, I shed a tear & shut down the engine before I offered another destroyed cam to the cafe-gods.
What are my potential problems and what are my potential solutions? I've never heard of a failed oil pump on a cb350, but is this a possibility? I should be able to leave the engine on the frame and take off the right engine cover to pull it & inspect it & if need be replace it? Beyond that, the only thing that coming to mind is that somehow one of the oil routes is blocked.
I'm open any ideas...
I'm going to go chug some whiskey.
-cfogs
-cfogs
