1969 CL350 Brat Build
I do the original rear pieces i cut off the behind the rear shocks and cut them at the angle to get them to match the transition, then plated the back side. Welded it all in and filled it with some kitty hair to make it smooth for paint.
more pic, once i have my fork seals, i'll rebuild the front forks
update!!!! Motor is about ready to have the top end assembled. I should have it knocked out this weekend. Drilled and started polishing the sprocket cover. And the bike is now a roller!
Well done man, keep it up. BTW where in AZ you located? I grew up in Phx and visit every month or so
these are not the bars i will run, thinking on some moped cafes and i have to get the speedo face so i can put it back to gether.
