My Dad and I are having a heated discussion about vacuum sync'ing carbs vs. bench sync'ing.
He believes, with all his heart, that you can't get any better than a bench sync; that all butterflies, throttles, slides, etc. are mechanically, physically exact and that anything you do after that will disrupt the equalization.
I believe that vacuum sync'ing will account for differences in the engine from cylinder to cylinder. Low or different compression, valves, etc.
Please educate BOTH of us on which one is better (vacuum... 8) ) and why. Please provide plenty of evidence, documentation, proof, videos, links, etc. My Dad is very skeptical of information on the internet. He's from the school of thought that "Anyone can put anything on the internet...doesn't mean it's right. I can type in that bench sync'ing is best and vacuum is wrong".
I personally have had very good luck with bench sync'ing. I've had a few bikes that were perfect right off the bat once I put vacuum gauges on them, or so close that it wasn't worth messing with.
I've also seen where all four carbs read differently.
We're currently working on a set of CV carbs. I tried to explain to him that, especially with diaphragm carbs, unlike mechanical slides, that even a bench sync won't make the diaphragms/slides rise uniformly. When I asked him "OK, I bench sync the butterflies and put the gauges on it and one carb/cylinder has 10 inches less vacuum.....what do you do?" HIs reply? "Take off the gauges and throw 'em away."
Help me out here. or, if I'm wrong, say so and explain why.
I'll be cross posting this on several forums to get a wide range of opinions.
