Hi Folks,
Just a quick heads up for those running ballistic batteries and want a good balancing charger, I just picked up a ballistic bms battery charger thinking that it would be the best option for my ballistic battery.
To start, I have no issue with the charger, it seems to work wonderfully and supports basically any battery that you could want. So far I've used it to charge a lead acid battery (gel type) and now my ballistic battery. Any tinkerer will love this charger, you can pretty much set it to charge however you want.
On the bad side, as soon as I took the charger out of the box I could see it was a re-branded charger (you can see the painted on label through the ballistic label), this doesn't bug me and is pretty much expected. As a good internet goer I googled the label and found this...
iMAX B6AC
Which appears to be the exact same charger, no programming adjustments or anything (the charger even says imax6 when you turn it on). The only thing that is missing is the 5 pin connector, but that isn't too specialized anyway.
As a bonus the imax6 manual (found here) is way more complete then the ballistic bms manual.
Cheers
iMAX B6AC
Cheers
