Ease
83 XJ650RK, 77 TS-250
This is a repost from another area.
I figured I'd give it a shot over here - Make me an offor if you want... Otherwise I'll probably just hang it back up in the garage...
Center to center the bolt holes are approx 6cm.
Distance across from the outside is about 13.3cm (has some stretch/shrink-ability for squeezing it on, though it is a brace, so it isn't flexible enough to pull it apart with your hands.
Here are a few Pics:
I'm considering e-baying it if ya don't want it.
It's not perfect, and there's a small chip in the paint on the brace (not rattlecanned, base+clear), the fender has the stripes buried under clearcoat, but to be perfect would need a wet sanding and a buff to make the whole surface level.
*Edit* to be perfectly clear - I did make this myself so it's not absolutely perfect (the brace, I never made the fender).
The fender itself has a small "twist" in it. My plan was to drill the mounting holes in the fender just a bit more to allow for some adjustability, but I ended up repairing my stock fender and really liked the way it looked... so this one has just been collecting dust, as you said.
