nice polishing work man i know how time consuming that stuff can be but i admire that alot of guys just paint those covers. I painted my engine case black but am already regretting it black shows every knick. I will prob strip it down and repaint it at some point. engine is looking stellar though look forward to see what you come up with here.
Luckily I have a monster 14" pedestal buffer to cut some of the work down. I just wet sanded the covers with 400 then 600 grits and went straight to the buffer through 3 grades of compound. I'll likely get the engine wrapped up this week and then get onto the frame and seat next.
The covers on the left side weren't so bad to do. The right side is a huge pain in the butt, mine had a lot of pitting and a few scars. I had to work with files, a dremel and start sanding with 120 grit and work up from there... I worked a few hours yesterday on it. I'm gonna finish it with 600 grit and a buff tonight. I want to be sure that when people see my bike that they "know" I put the needed work in the right places... and didn't skimp on money or labor. (Though I'm being careful not to just throw money at it. Even if it feels like it.
Exactly the problem I had. I ended up with paint after spending hours trying to get them smooth enough to even consider polish. I'm still pleased with the way they came out, too.
I actually do not have a bench grinder... Not really a fan of them. I use a belt/disc sander as a grinder and have a big dedicated 14" pedestal buffer for polishing. I keep saying that I need to pickup a bench grinder and just install wire wheels though...
I would have had the left side done in an hour if it were'nt for the pitting. My bike wasn't the best maintained bike before I got it... The pitting wasn't that noticeable until I started polishing... then the pitted parts just looked like dark spots... So then I had to get after that. Plus there are a lot of ithght curves (which is exactly where most of the pitting was located.) I am polishing the right side cover form my spare engine. The one that is on the good engine might be in better condition but I did not remove it yet... as I figured I'd just remove the old and replace it with the polished one in a single sitting.
Oh, I've had several over the years and they don't get much use at my shop... I end up giving them away to friends. I don't have one out of preference.
crazypj said:
A 14" polisher probably has a 2hp+ motor, much better than a bench grinder
carbs are on the way, I sent tracking number
My valve spring compressor came today. I'm gonna remove the valves and get that casting cleaned up and ready for paint after grilling some bacon cheddar burgers.
everything is lookin super so far. did you use a drop of sealant or anything on those stainless bolt threads...stainless is the worst about galling w aluminum.
lets see some pics of the homemade soda blaster.
A bit of blue thread locker on the threads. The soda blaster is just an airgun and bit of hose... Nothing worth showing. I'm sure I'll slip a shot in eventually.
