www.Moto-Madness.com
Author Topic: Now You're Gonna Get It... Bobby! SR250  (Read 12533 times)
Offline ProSimex
  • RUN SCREAMING!!!
Re: Now You're Gonna Get It... Bobby!
« Reply #10 on: Mar 08, 2013, 10:44:52 »
a special place in hell is reserved for those who put sprung seats on their swingarm bikes. Other then that I like it all so far.
"Love is the feelin you get when you like something as much as your motorcycle."
"That's got CV's? Take a #2 phillips screwdriver, heat the tip with a torch until cherry red and plunge it into your eye. It will hurt less. Really."- Kopcicle
Offline DesmoBro
  • Busted Nut
« Reply #11 on: Mar 08, 2013, 10:49:09 »
yea it looks a bit off....but it came to me this way only as a pile ....Maybe I will change the seat out but it has to run first
"I desire the things that will destroy me in the end"
Offline Rich Ard
  • doin' the backstroke in an estrogen ocean
Re: Re: Now You're Gonna Get It... Bobby!
« Reply #12 on: Mar 08, 2013, 10:53:42 »
Think that's in Leviticus, right? :)
unplug the connectors from the harness and multimeter the shit out of them
Bad Points, a comic :: CB450 Restomod (sold) :: Viragostrosity :: GL1000 daily rider :: Kaw 175
Offline Brodie
  • Gold Coast, Queensland
« Reply #13 on: Mar 09, 2013, 09:06:01 »
I think there is too much of a gap between the suzuki tank and the seat but the other looks a little tall.
Have you decided on which tank you are going to use?
As for the spark check the safety relay as I had problems with mine and made a jumper to replace it.
Offline DesmoBro
  • Busted Nut
« Reply #14 on: Apr 14, 2013, 00:07:24 »
searching for a regular sportster tank the one i have is an XL ...I'm also looking for a dirt bike header so I can mount the pipe up high in the rear.... i also took them springs off the seat
Offline Brodie
« Reply #15 on: Apr 14, 2013, 00:09:25 »
Check out the Yamaha XT250 and TT250 should be able to get a header from them.
Offline DesmoBro
  • Busted Nut
« Reply #16 on: Apr 22, 2013, 23:25:18 »
Swap meet came in handy spent $100 and none of it will be going on this bike!.....Someone please light a fire under my ass over here I should be riding this little squirt....FINALLY HAVE BUILD FUNDS PEOPLE all I had to do was sell off a Vintage Ducati :'(....I wonder if it made it to NJ ok....The guy Bungee corded in between 2 concrete Lions :o
Offline Brodie
« Reply #17 on: Apr 23, 2013, 01:16:56 »
That just sounds like a horrific way to tie down a bike.
What is your next move for this bike. Maybe with the funds you could grab the tank you want.
Offline DesmoBro
  • Busted Nut
« Reply #18 on: Apr 23, 2013, 17:27:12 »
Good Call Man....That reminds me I should Try and trade off this Huge Tank for the one I need....In the mean time I promised my self I would
Weld the mounting bracket for coil
Cut and Weld the New Header I got 4 ($20)
buy the adapter pipe to fit the Harley muffler to the
Mount the heat guard on the Muffler
Run the Wiring and figure out where to mount the stuff
Make and weld Gussets to the frame
Man up and extend the Wire thats attached to the clutch lever to make this Jockey Shift(which is going to be Bad@$$)
gonna put the computer away now and actually do what I should have done by now...pictures soon
Offline DesmoBro
  • Busted Nut
« Reply #19 on: Apr 26, 2013, 22:03:15 »
mocking up exhaust before tacking it together
« Last Edit: Apr 26, 2013, 22:05:18 by DesmoBro »
