www.Moto-Madness.com
Author Topic: Simplified Wiring Digrams  (Read 94081 times)
Offline ILoveThumpers
  • Everywhere is thumpers!
Re: Simplified Wiring Digrams
« Reply #30 on: Sep 30, 2013, 15:14:12 »
Either of those are fine.
Those must ground through the case? Very clean. I like it.
Sonreir do you know of any R/R units that regulate to a higher voltage? (Like 30v, for instance?)
-Deek
There are only two types of riders: those who have dropped their bikes and those who will. Be prepared.
1980 Suzuki GN400. Stock... for now
1975 Honda GL1000. Reassembly has begun!
Offline Sonreir
  • Moderator
  • Oregon
« Reply #31 on: Sep 30, 2013, 16:12:52 »
-Deek
Not off the top of my head.  For what purpose?
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
« Reply #32 on: Sep 30, 2013, 17:37:27 »
I had toyed with the idea of using a high-powered LED package as a headlamp but they always have forward voltage requirements well over 12v. To avoid adding a DC to DC converter, I thought about regulating up to 30v for the headlamp and using another regulator to run my 12v components.
-Deek
Offline Sonreir
  • Moderator
  • Oregon
« Reply #33 on: Sep 30, 2013, 19:05:25 »
I think the DC/DC converter would be a better option, especially since LEDs are generally low current devices.
Google "30V LED Driver" and find something that can handle the current level you need.
Offline nixoid
« Reply #34 on: Sep 30, 2013, 19:19:19 »
That assumes you're using points, however.  Gets trickier with some of the electronic ignition systems.
This is a USCRA F160 racer so I have to keep the points. If I decide to move to 200 GP I believe I can abandon points. Would there be a lot of re-engineering to upgrade to an electronic set-up?
Kev
Offline Sonreir
  • Moderator
  • Oregon
« Reply #35 on: Sep 30, 2013, 19:59:33 »
Kev
Depends on the setup.  Most aftermarket units are pretty straightforward, but the stock units can be a bit more complicated.
Zookrocker
  • Guest
« Reply #36 on: Nov 04, 2013, 04:23:31 »
Thanks for these fellas...great info here.  I'm want to wire up my GS650 from scratch.  Any major changes for the 4-cylinder from something really simple, like Sonrier's first example?
Offline Sonreir
  • Moderator
  • Oregon
« Reply #37 on: Nov 04, 2013, 10:23:21 »
In the first example I don't include much wiring for the ignition system and that would be a concern (especially if your ignition is electronic).  Also take a look at the alternator and charging system as those will almost definitely be different.
Zookrocker
  • Guest
« Reply #38 on: Nov 04, 2013, 15:31:28 »
Thanks Sonreir...can I PM you with questions?  Are you still selling custom harnesses?  That might be the way to go...you do nice work
Offline Sonreir
  • Moderator
  • Oregon
« Reply #39 on: Nov 04, 2013, 15:32:08 »
Please feel free to PM.  I'm glad to help.  Custom harnesses still available, too.
